Sprint Dash Harness to Main Harness Connections
lotusfan wrote:Very interesting reading Phil. My original housing was damaged as a pin had melted and I too used a Tyco Mate-N-Lok connector in it's place, the pins were a bit loose but it seems to be OK.
My Sprint has the multi-way white plastic connector - that also has a couple of pins melted through the housing.
I have yet to see anyone be apportioned with the credit (blame....) for the electrical design of the Elan, but it really was dreadful.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
gjz30075 wrote:Phil, please post pics of the finished product.
Here you go Greg, almost done:
Only the Steering Column left now; Been a busy winter... I have:
Replaced the crashpad (a ***ch of a job)
Rebuilt the Heater Fan motor (has not worked since I bought the car)
Rebuilt the windshield wiper motor & wheel boxes
Rebuilt the steering column with new bushes
Added Sun Visors back
Replaced the nasty generic loom connectors with a "correct" molex connector
Can't wait to drive it again...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
elancoupe wrote:Phil, could you elaborate on how you rebuilt the wheel boxes?
There's not really a lot that is needed / can be done - just a thorough strip down & regrease.
Unfortunately I managed to do a 180 degree on the wheel boxes when I re-assemble the wiper motor / shaft / wheel box assemblies:
It was difficult to assemble the wiper mechanism into the car even without the dash & wiring harness & after installing them the wipers went the wrong way onto the hood (bonnet)
After scratching my head for a day or two I realized that the wheel box wiper axis should be above the line of the wire, pulled the mechanism out & spun the wheel boxes 180 degrees & now everything works as designed.
This is a picture of everything assembled the right way:
Phil Harrison
Closing the loop on this with more information on the original connectors.
Dick Britton very kindly donated the 12 pin multi-way connectors from his 1970 S4; here are photos of both the male (AMP 163031) & female connectors (AMP163032):
It looks like some parts may be available - https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/1-163032-0/1-163032-0-ND/1861121 & https://www.onlinecomponents.com/te-connectivity-amp-brand/11630310-44159389.html
That is, if you're prepared to but 1000+
Phil Harrison
