Original Relay positions Elan Sprint
Does anyone have a photograph showing the original relay locations and functional identities for the 71 Elan Sprint? I have seen two or three photos in this forum but dont know which is original.
Bob
Bob
bloodknock - Fourth Gear
Thats what Im talkin about. The two Headlamp relays, the flasher the failsafe and the horn.
Thanks Phil
Thanks Phil
I've been converting my car back to how it left the factory... here are the best pictures that I have found
That top relay (dipped beam) is pretty tucked under the bonnent hinge.
Here is an earlier car:
You should see the original mounting holes in the inner wing (fender).
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Thank you gentlemen. Came up trumps as usual.
Bob
Bob
l10tus wrote:Make sure you face the can of the 6RA relays forwards, this helps reduce water ingress in through the baseplate? Always ensure the connectors face backwards.
The original relays were quite easily contaminated by UK weather otherwise.
Phil.
Mine were mounted with the connectors straight up when I bought my car. Every single one had rusty water in it.
Dan
Can anyone tell me where the correct home is for the Air Horn Relay?
I have the correct red relay and Air horns that came with the car (the car was in boxes when i got it) but i also found a pair of snail horns that look original, so i suspect the air horns where bought at some point as an Upgrade.
Thought it would be better tagging my question to an old thread rather than starting a new one.
Grizzly - Coveted Fifth Gear
I believe air horns were a dealer fit rather than a factory fit (Happy to be corrected though).
In which case there's unlikely to be a "correct" position
'72 Sprint
'72 Sprint
- richardcox_lotus
According to Tim's excellent web site the Air Horns are listed as Options (but that doesn't mean the dealer didn't fit the option selected a bit like the Electric aerial)
http://www.lotuselansprint.com/Document ... ceList.pdf
