Hazard Warning Light - S4
Posted: Tue Nov 05, 2013 1:23 pm
Hi All,
I've read the archive and there appears to be a problem with the standard wiring. If the indicator is on, and the ignition is off, switching the Hazard switch on makes circuits live that shouldn't be.
There appear to be two solutions:
1. Replace the standard switch with a DPDT one and isolating the indicator feed
2. Using a diode in the indicator circuit to prevent the reverse feeding of the indicator circuit.
I prefer the Diode solution as it is simple and requires no alterations to the standard wiring. but I'm getting lost in the technicalities of diodes....
The normal load on the indicator circuit is 21W + 21W + 5W = 47W approximates to 4A at 12v
So I need a diode capable of handling 4A (lets say I need a 10A diode to keep the forward voltage down)
Can anyone recommend a suitable diode?
Will the indicators be significantly dimmer/slower?
Thinking further could I isolate the indicators feed with a relay powered from the hazard switch?
Anyone any other simple solutions?
