MGB Headlamps
The Lucas 7 inch headlamp was a standard fitting on many of the British cars of the 60s and 70s. I own an MGB as well as the Lotus, and the lamp components are identical.
TroonSprint - Fourth Gear
I think that I once read somewhere that there is a difference in the chrome trim rings,
Apparently the ones used on the Elan have a flatter profile i.e. less bulbous in shape.
I think that this flatter profile facilitates assembly & removal from the headlamp because the space between the trim ring & the headlamp pod is very limited at the bottom where you need to get a flat metal hook into in order to remove that ring.
Beware of the Illuminati
gjz30075 wrote:John, that's interesting. Mine are, I believe, bulbous and very difficult to remove. What do you have on yours?
Perhaps a new thread is needed here. Pics anyone?
Greg Z
I have never needed to buy replacement headlamp trims & have the ones that were on the car when I bought it very second hand. For that reason I cannot say if they are original equipment or not.
Nevertheless they are most certainly not the easiest things to remove or re-fit
I'm trying to think how a photo would help here unless someone has the different types to put side by side as a direct comparison.
A section cut through the actual parts would provide a definitive description; any volunteers
When I replace mine back in about 1975, one was missing and the other corroded. As far as I can recall back then the MBG ones I got were identical to the corroded one I replaced. And yes they are both very tight fits at the bottom.
