Indicator warning light.
My green indicator warning light only flashes once when indicating, although the external lights work OK.
I have recently changed the flasher unit, although this problem was present before the change.
What might the problem be?
- Hongokongo
Thanks, I will look at that. However, it may not be the wiring as the light comes on once, and then goes out, and that's it.
- Hongokongo
Later.......I only have two wires, not three as in the diagram. I am missing the one that goes to the indicator switch, so how does it come on at all?
- Hongokongo
Have a look here.....
lotus-electrical-f38/sprint-indicator-flasher-unit-t25463.html?hilit=flasher%20warning%20light#p166423....... explains wiring for a two wire flasher unit.
S4 DHC
S4 DHC
- oldelanman
It is difficult to imagine how your circuit is presently wired to achieve your symptoms, but the topic Roger pointed to has this diagram, which does show a way of achieving the target effect with a two-wire flasher.
In that version the indicator is wired between the live sides of the Left indicator lamps and the Right indicator lamps. When you move your steering column switch you activate the interrupted (flashing) voltage to one side (say the Right side) That operates the body signals, but in addition current flows through the dashboard indicator AND THROUGH THE BODY INDICATOR BULBS ON THE OTHER SIDE to earth. The big bulbs are much lower resistance than the dashboard lamp, so the dashboard lamp conduct only enough current to make it glow, with insufficient current through the body bulbs to make any noticeable glow at all.
Picking up this thread ... I have the same problem except I have a 3-terminal flasher unit.
The flasher unit clicks audibly once at the same time as the indicator warning light flashes and then both appear to stop although the indicator lamps carry on working fine on both sides of the car. The hazard warning light - which on the wiring diagram appears to share the same earth as the indicator warning light - also works fine.
Have tried a replacement flasher unit but no difference.
Grateful for any suggestions?
tim22 - First Gear
Some of us did some work on this recently in a post started by john.p.clegg. titled (Indicator relay).
To save doing it again does anyone know how to refer to that thread. I have tried to find it in the archives but cannot find out how to refer the questioner to it. It will be useful to me to be able to do that as well.
Eric in Burnley
S3SE DHC
Eric in Burnley
S3SE DHC
- ericbushby
Eric
Here
lotus-electrical-f38/indicator-relay-t33074.html
P.S. I went to my posts...and searched...pity I couldn't go to threads I started...
Here
John.
Thankyou, got it.
A new search box comes up that I haven't noticed before. I was trying to use the one at the top right of the page.
Eric in Burnley
Thankyou, got it.
Eric in Burnley
- ericbushby
Users browsing this forum: AlanJH and 30 guests
