Tuning a Lucas Distributor.
I'm making a fresh topic here so that the link to this highly useful document is easy to find in future.
http://www.vitessesteve.co.uk/PDF/lucastuning.pdf
It tells you how distributor advance curves REALLY work and how altering the curves is done by changing springs and not by changing weights as many persons erroneously expect.
Documents referenced on the internet from the above document may have moved.
A Lucas Distributor database document can be found at:
http://www.starchak.ca/tech/pdfs/lucas.pdf
Des Hamill's book ?How to Build and Power Tune Distributor-Type Ignition Systems?
can be found on Amazon at:
http://www.amazon.co.uk/Build-Distribut ... 1845841867
The Southern Springs site is still there:
http://www.southernsprings.co.uk/
These links
can probably be found at:
These links
1. Chichak, Marcel F. ?Lucas Distributor Data? latest release 2002
http://www.telusplanet.net/~chichm/lucas.pdf
2. Chichak, Marcel F. ?Ignition Advance Curve Requirements? 2001 draft
http://members.tripod.com/mini_digest/ignition.htm
5. Chichak, Marcel F. ?Inexpensive Modern Electronic Ignition for A and B Series
Engines? latest release 2001 http://members.tripod.com/~mini_digest/dizzy.htm
I think Distributor Doctor may sell the springs as well as providing a whole rebuild service.
http://www.distributordoctor.com/
Users browsing this forum: No registered users and 44 guests
