White with purple tracer cable
PostPost by: MickG » Wed Jun 19, 2013 11:30 am
As above 28/030 cable. Anyone know of a supplier, only want a couple of metres.
Regards Mick G
MickG
PostPost by: c42 » Wed Jun 19, 2013 12:18 pm
c42
PostPost by: MickG » Wed Jun 19, 2013 6:50 pm
Thanks John,
Tried them, Apparently White/Purple is a odd colour. May have to use something else and amend the wiring diagram accordingly.
Length has now gone up to 3 Metres.
Regards Mick G
MickG
PostPost by: stugilmour » Wed Jun 19, 2013 9:08 pm
I think these guys have it by the metre in several gauges, thin wall or standard. Have used both suppliers in the past and they are both good. Just curious, what circuit are you using that colour for?
http://www.vehicle-wiring-products.eu/V ... inwall.php
HTH
Stu
1969 Plus 2 Federal LHD
PostPost by: MickG » Wed Jun 19, 2013 10:21 pm
Hi Stu thanks for that I have looked on their site before and could not find it. Certainly there now.
It's for the circuit from the ignition switch to the fuse box(71 UK Sprint)
Thanks again
Mick G
MickG
PostPost by: cliveyboy » Thu Jun 20, 2013 8:16 am
I remember being in a similar situation when I needed a length of Purple with black tracer.
I had some purple wire and ended up putting the black trace on myself.
Sounds crazy but worked really well.
I got a piece of wood/metal drilled a hole through that was the size of the cable then drilled another hole at 90 degrees that was just big enough to get the nib of a thin permanent marker pen through. I then pulled the wire through whilst holding the pen in the hole and it traced a black line the length of the wire.
If you looked really closely you could figure out what I did but once installed you would never know
Clive
1972 Elan Sprint FHC
cliveyboy
