Source of License plate lights on S4 & Sprints?
I will need a couple of gaskets to go under the rear license plate lights. Looked through Matty/Miller/Bean catalogs with no success.
I have done a search here, but not found an answer to the source of these parts. Some suggestions that they may be ex-Volvo 240 (add heaviness...)
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Just pulled "Robinshaw & Ross" off the book shelf, lists it as :
Hella 2KA.001.378.00 or Hella 12958 R4, now what the heck were they used on?
I knew there was a reason a paid a lot for the R&R books!
Phil Harrison
SJ Sportscars list the lamp........http://www.sjsportscars.co.uk/index.php?mod=10
S4 DHC
S4 DHC
- oldelanman
When I bought new one's last, which must be nearly 20 years ago, having found the right Hella item, I looked at the cross reference chart, and saw they were listed for a Mercedes van. Even heavier than a Volvo.
- ricarbo
They are a Universal Number Plate Light used on many current European Trucks, the correct Hella Part Number for the Chrome one is 2KA001378-001 and they are current production so you should be able to Order from any Hella Distributor at about GBP 8.75 they are also available in Silver and Black under different Part Numbers
PeterExpart
New Forest National Park
Hampshire UK
Hampshire UK
- peterexpart
Thanks for all the info guys, I found the following applications (Original part numbers):
Auw?rter: 11025348, 1503.400.00
DAF: 055 7096
Deutz-fahr: 043 96049
Knaus: 050858, R01010036
MAN: 81.25225.6111, 82.25225-6111, 83.25240.6001
Mercedes: 000 820 12 60, 001 820 14 56, A 000 820 12 60, A 001 820 14 56
Neoplan: 1102.534.8, 1503.400.00
Scania: 257 933, 478 344, 492 205
EAN Code: 4082300211511
So as PeterExpat says, "a Universal Number Plate Light used on many current European Trucks". Unlikely that I will find it in the States, but someone has kindly offered me their old gaskets, so I may not need to!
& btw as oldelanman says, SJ Sportscars do stock them. Sue Miller & Paul Matty stock the light as well, so plenty of sources in the UK.
This is LotusElan.net at it's best, elan nuts helping each other!
DAF: 055 7096
Phil Harrison
Thanks to pamitchel I now have a nice pair of seals for the license plate lights - thanks Phil.
For the record everyone now knows where they came from & where they the lights can be sourced.
This is lotuselan.net at it's best.
Here are a couple of pictures of the top & bottom of the seal:
Phil Harrison
it is still manufactured by Hella, see p46 on the online catalog
http://www.hella.com/hella-be/assets/me ... rhomes.PDF
though the gaskets I've seen are only made in black and not in the greyish rubber as originally on my car (I shall add that the Hella number on my rear plate lights is K 12813, of similar appearance as the 12958 one can still source easily today)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Thanks for posting the catalog, it shows the different variants:
I recently bought a pair of the 378-041s, they are made in India & are OK but the finish is a matt silver rather than bright chrome, as you mentioned the gaskets are also black instead of grey:
I put this down to the Indian Manufacture, but with the catalog showing that the correctly silvered ones are still manufactured I have just ordered a pair of the silver finish ones 378-001 from Spare Parts store (http://www.sparepartstore24.co.uk/933532-hella
I'll report back on the quality once they have been delivered.
Phil Harrison
I suspect that the grey gasket is merely grey with old age and probably started black.
billwill wrote:I suspect that the grey gasket is merely grey with old age and probably started black.
No I don't think so, it's not surface bloom... Grey through & through...
Phil Harrison
Seems they are easy to get hold of at a sensible price ..
Carl
Carl
pereirac - Coveted Fifth Gear
