S1 boot light protectors
• Page 1 of 3 • 1, 2, 3
I know these are available from the 26 Register, but if anyone could sketch the dimensions for me and sheet metal thickness I would appreciate it. These would be the trapazoid shaped ones. I was just going to make a pair up so the lights and wires stay protected. I could make up my own to fit but want to try and replicate the original ones.
- Tahoe
It's amazing how minor things can be an important issue, I also had the wires and globes
"messed with" by my photography gear moving around in the boot while having
a "pleasant" Sunday morning drive in the Alps one summer.
So decided to make up some aluminium brackets as shown in the pics, no need to
give measurements as you simply take them on the topmost light mounting studs.
After fitting the brackets... end of problem.
Don't get to fancy with the design, as you will still need to get at the globes, and
don't make the bracket to wide for same reason.... I never new that orig protectors
were ever used, but anyway this does work.
Live your dream-wear your passion.
http://elantrikbits.com/lotus-elan-blog/
- ceejay
Grommet goes into the center U shape and the wires are fed through
I didn't know those existed! Did S3s and S4s have those?
Andy
Andy
- abstamaria
piss-ant wrote:Hi Andy
The S3 and S4 used the cardboard trim finish piece to do the job.
Gary
That's interesting Gary. My Plus 2 originally used a similar cardboard deal. I ended up just covering the lights with carpet and the soundproofing felt as the cardboard was pretty far gone. I think I will try something similar to Col's item, although I haven't had any issues with the carpet covering.
Stu
1969 Plus 2 Federal LHD
Gary,
Thankyou, thankyou, thankyou for the pictures with dimensions.
I'll make up a pair, and if they look and function good I'd be willing to make others for those interested.
As a side note my cast oil pan project I believe is dead. Too much money needed to invest in a project that few are truely interested in.
- Tahoe
The pictures Gary posted for the S2, look exactly like mine.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Here's a protector in situ on my S1
As an aside - has the inside of your boot been painted?
Mine has never been painted and never will be painted
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa - Fourth Gear
Hi Rod
Unpainted inner boots may therefore be fairly common!
The Type26 Register states that they should be either grey or black - so an edit is required!
http://www.type26register.com/body_colours.html
Gary
Gary, Many thanks. I didn't know that such a piece existed! How is it held on?
35 years of Elan ownership, and there is still so much I don't know.
Best regards,
Andy
- abstamaria
abstamaria wrote:piss-ant wrote:Hi Andy
Gary
Best regards,
Andy
Andy,
The **millboard ** doesn't offer much protection. However, my '67 S3 has a couple of narrow steel brackets (which I can't locate at present! ) and the millboard is held onto them by self tapping screws that go into spire nuts. Here's an "artists" impression
(Ref: http://www.sjsportscars.co.uk/index.php ... found=true)
(** Millboard** http://www.woolies-trim.co.uk/p-1648-millboard.aspx)
Hopefully someone can provide dimensions for the bracket.
Cheers - Richard
- ardee_selby
Dimensions should be 3.75 inch by 1.5 inch by 1/2 inch, I straightened the bracket incorrectly and the next two pictures show how the brackets should look.
Gary
Gary
Gary,
Do both the S3 & S4 rear light units have same spacing of fixings (and therefore use same brackets)?
Cheers - Richard
- ardee_selby
