How long will points last without a condensor?
I was out with a mate who had a condensor fail, luckily I found a spare but I considered cutting the wire as a " get you home method", how long would the points last? Any thoughts or experiences guys?
- AussieJohn
Don't think it will run at all without the condensor, so presumably forever -
- Jon Eckman
I think Jon is right there, though I'm not 100% sure, only about 98%
Henry
1967 S3 FHC
A joke a day helps you work, rest, and play.
1967 S3 FHC
- Henry VIIII
Hmm, I thought that it was to squelsh arcing as the points opened but am open to other points of view, cheers, John.
- AussieJohn
If you are very lucky and can start it, which with a relatively capricios engine with twin webers I doubt, then it would run very roughly to about a maximum of 1500 rpm with barely any power and not accept anything other than a tiny throttle opening.
Been there done that got the T shirt.
Basically you get a very weak spark if anything at all.
A coil ignition system relies on a fast clean opeinng of the contacts and a way of storing and dissipating the back EMF to ground which would otherwise arc across the points massively reducing the coil output voltage.
In the days when I was regularly servicing cars with points I found that there was more risk of a new condensor being faulty or failing prematurely than in leaving the old one in situ if it was in good health, this could be judged either by the condition of the points or by the CRT trace on a Crypton tester or Sun analyser.
- Chancer
Chancer wrote:If you are very lucky and can start it, which with a relatively capricios engine with twin webers I doubt, then it would run very roughly to about a maximum of 1500 rpm with barely any power and not accept anything other than a tiny throttle opening.
That's been my experience as well when I had a spate of them go many years ago. The engine would just about run but wouldn't produce enough power to move the car. Cleaning the points would improve things and might get you a couple of hundred yards but given how hard it is to get to the points on the Elan you'd be quicker pushing.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Thanks for all the info. guys, I guess carrying a spare is the answer, cheers, John.
- AussieJohn
AussieJohn wrote:Thanks for all the info. guys, I guess carrying a spare is the answer, cheers, John.
Aye, I've had to replace a condenser, on the road, before now. They don't actually have to be inside the distributor, so if one fails inside, you can cut/break its wire & then fit a temporary one outside the distie. Then fit a proper one later.
Henry
1967 S3 FHC
1967 S3 FHC
- Henry VIIII
..and if you do the above,don't forget to earth the condenser case..
Edit
You don't have to earth it twice,probable finger shake...
Edit
john.p.clegg wrote:..and if you do the above,don't forget to earth the condenser case..
Edit
My 'spare' condensor is already bolted to an engine point, with a flying lead fitted with a passthrough connector for the lead to the coil.
Henry
1967 S3 FHC
1967 S3 FHC
- Henry VIIII
