What thread?
PostPost by: AussieJohn » Sat Jun 09, 2012 8:37 pm
Does anyone have a clue as to the thread on the speedometer where the cable screws on. It seems to be 12mm at 1mm pitch but I didn't expect a metric thread; any thoughts?
AussieJohn
PostPost by: AussieJohn » Sun Jun 10, 2012 5:19 pm
Come on guys, where are you techy types with all the answers? cheers, John.
AussieJohn
PostPost by: garyeanderson » Sun Jun 10, 2012 9:24 pm
A google search turned up this post
http://www.triumphrat.net/classic-vinta ... reads.html
"The cable thread for Smiths tacho/speedo is metric: 12mm x1.0 .
It seems to be common on Japanese gauges too.
The square drive on the inner cable for Smiths gauges is not metric,its 1/8" square.
Japanese inner cables have a metric square,usually 3mm.
Thread size shouldn't be a problem.The size of the square drive could be a problem."
I tried a 1/2 x 20 as I don't have any 12mm anything that I know and the nut starts on the speedo cable thread on the speedometer but only turns a turn or two before it starts to lock up so the 12 x 1.0mm would seem to be a good start. All I really know it the speedo cable threads onto the speedometer and thats what counts.
Gary
garyeanderson
PostPost by: elansprint71 » Sun Jun 10, 2012 11:20 pm
AussieJohn wrote:Come on guys, where are you techy types with all the answers? cheers, John.
Might be worth asking the folks at Speedy Cables?
PostPost by: AussieJohn » Mon Jun 11, 2012 5:43 am
Thanks guys, cheers, John.
AussieJohn
PostPost by: ceejay » Mon Jun 11, 2012 10:49 pm
Hey guys...chiming in here a bit late.
Threaded boss on the back of the speedo is: 12mmDia X 1mm thread pitch.
Ceejay
PostPost by: garyeanderson » Mon Jun 11, 2012 11:07 pm
ceejay wrote:Hey guys...chiming in here a bit late.
Ceejay
Thank you CeeJay for confirming the internet search. Sometimes it does actually gives you the right answer if you spend a few minutes looking and putting in various search terms.
Gary
garyeanderson
PostPost by: ceejay » Mon Jun 11, 2012 11:13 pm
When I read the posting I just wandered out to the W/shop as the elan
dash is sitting on the bench waiting for some work to be done,
so it was easy to grab the vernier and thread form gauge to check.
And then saunter back to the PC to post the results.
So no probs.
Ceejay.
Live your dream-wear your passion.
http://elantrikbits.com/lotus-elan-blog/
PostPost by: AussieJohn » Tue Jun 12, 2012 8:43 am
Thanks everyone for all the advice; it is for a friend who is wanting to use an original speedometer with a mt75 gearbox that has an electrical speedo output. A company in the States is making a motor drive to mount on the back of the speedo to retain the mechanical odometer. cheers, John.
AussieJohn
PostPost by: Elanman99 » Wed Jun 13, 2012 9:45 am
Thats sounds an interesting approach. Unless I have missed something obvious the whole thing could get quite complicated and be quite costly. I would have thought that the mounting thread details are the least of the problems. Its the sort of thing I might have considered doing for myself but it certainly would not be economically sensible.
The motor driving the speedo will either have to be a stepper type (might not be silent) or servo controlled to exactly mimic what would have come out of the original gearbox pinion shaft.
I have the impression that I have seen visually identical, but electronically operated, instruments advertised recently, they would be a much more sensible option.
Ian
Elanman99
PostPost by: ardee_selby » Wed Jun 13, 2012 11:01 am
AussieJohn wrote:Does anyone have a clue as to the thread on the speedometer...
When you said "thread" I thought you meant thread as in a "forum thread". I've been searching the archive for bl**dy ages without success! D'OH! :roll:
Note to self: Read all posts carefully! :wink:
ardee_selby
PostPost by: c42 » Wed Jun 13, 2012 12:14 pm
A bit late here but I believe that it is very easy to convert the MT75 box from electric speedo drive to mechanical.
c42
PostPost by: prezoom » Wed Jun 13, 2012 3:23 pm
Abbott Enterprise also makes a converter from digital to mechanical. Can find them at: www. atrol.com.
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: AussieJohn » Thu Jun 14, 2012 6:40 am
Wow, a lot of good info. here, I will pass it on, cheers.
AussieJohn
Users browsing this forum: Superlight, thehackmechanic and 17 guests
