S3 S4 boot lid license/registration lights
Does anyone know the OEM way to attach these two lights? Currently, mine are attached with some sheet metal screws right into the fiberglass. This doesn't seem right; although I've had no problems, seems like there should be some speed nuts for the screws. So, anyone using the oem way, or some improved method?
Thanks.
Greg Z
Thanks.
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Hi Greg
This is what I got with 36/6292, it may not be the way the late Elans were put together but I didn't really want to take the lamps out of the 70 Coupe.
Gary
Sunday May 27th 10:35 am
Another photos of the lamp and spire nuts disassembled and somewhat cleaned.
Gary
Greg,
Can't recall exactly what was used originally, but definitely not any sort of captive nut. I ended up using stainless steel screws and nuts with ss spring washers. Because it is a bit of a fiddle getting the nuts started, I decided to replace the incandescent, festoon bulbs with LED bulbs. The LEDs last longer, use very little power and most importantly, create very little heat so the lens of the light unit will not melt. I used "warm white" LED bulbs with three LED elements and are probably too bright. The two LED units are probably a better solution.
Colin.
Colin.
gjz30075 wrote:Does anyone know the OEM way to attach these two lights? Currently, mine are attached with some sheet metal screws right into the fiberglass. This doesn't seem right; although I've had no problems, seems like there should be some speed nuts for the screws. So, anyone using the oem way, or some improved method?
Thanks.
Greg Z
Thanks.
Greg Z
'68 S4 DHC
- fatboyoz
My cars have had the sheet metal screws and speednuts (Tennerman). My improved method of retaining was to make pictured brass pieces (.032, .8mm thick). I drilled an undersized hole for the screw, then punched it to extrude some material for longer threads. I tapped the threads, but one could use self-tappers. I think I used #6-32 and I can't verify now as I'm in Ohio and the car is in Florida. I was only able to use one of these this time, since the laminations on the inside of the boot lid weren't flat. Also, be careful not to use too long a screw, which could touch the hot terminal and short out.
I have taken dimensions if anyone would care to duplicate them.
I too am concerned about the heat so I will be changing to LED bulbs.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Note the little 1/4" wide tab on the corner for the earthing wire.
'67 Elan S3 SS DHC
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Users browsing this forum: pdenton26 and 30 guests
