S3 Wiring - Dynamo
Wed Apr 25, 2012 12:48 pm
by AHM
Hi All,
The S3 wiring diagram says "Comp. where fitted" next to the dynamo.
What is comp.? is it what the little black wire is for, that piggybacks the main dynamo terminal?
It doesn't look critical and it has been taped-up.
Simon
Re: S3 Wiring - Dynamo
Wed Apr 25, 2012 1:04 pm
by ardee_selby
AHM wrote:Hi All,
Simon
I have always thought "comp" was a "typo" for Cond? Condenser? (or something
) referring to the
"1.0 MFD suppressor connected to the "D" (larger) terminal" (in the w/manual under radio suppression) and the earth symbol represented "earthing clip secured to one of the mounting bolts"
I soon fitted an alternator, so haven't looked back...until now.
HIH - Richard
Wed Apr 25, 2012 2:42 pm
by alan71
If you look at the S4 diagram it's "horn comp when fitted".
Alan.
Wed Apr 25, 2012 6:27 pm
by Galwaylotus
...presumably meaning "horn compressor"!
Wed Apr 25, 2012 7:53 pm
by ricarbo
I agree, it looks meaningless and is probably an error. I think it's one of those many little difficulties found in the workshop manual wiring diagrams, but try looking at a modern car diagram if you want early admission to a psychiatric hospital!!
What worries me is that there are only two fuses, one of which does just the cigar lighter and horns, the other does all the rest and loads of other circuits aren't fused at all. Looks like a recipe for trouble to me.
atb
Richard
Thu Apr 26, 2012 7:58 pm
by Galwaylotus
Not necessarily an error if the car is fitted with air horns!
Fri Apr 27, 2012 5:39 am
by AHM
Thanks for suggestions.
The wire that I have is probably from a radio suppression capacitor.
I suppose that the air horn compressor is located by the dynamo, but what about the wiring?
Simon
Fri Apr 27, 2012 7:24 am
by alan71
from the S4 wiring diagram, I don't know if the S3 ever had air horns
Alan.
Fri Apr 27, 2012 2:30 pm
by Galwaylotus
The S3 wiring diagram has the same reference for "Comp when fitted".
Fri Apr 27, 2012 2:40 pm
Galwaylotus wrote:The S3 wiring diagram has the same reference for "Comp when fitted".
Errr....did I miss something
....isn't that what this thread is about as per the OP?s first message
