S4 Federal Headlamp Operating Rod - info required
PostPost by: terryp » Fri Jan 27, 2012 11:33 am
This is one of my missing parts and I have a few people looking for one but as yet no one has one.
The other problem is that apart from the parts manual I don't even know what it looks like!
Does anyone have a photo or better still if you are restoring the car and have the piece off some dimensions as I think its going to have to be made up.
Its the rod that fits between the pods, rather like the later+2 failsafe design.
Ray at RD has the small anti rattle joints/ rods that connect onto it so I am OK there.
Thanks again
Terry
PS In the parts book its plate BL BL22 036 B 1658 Rod, Operating
terryp
PostPost by: gjz30075 » Fri Jan 27, 2012 3:08 pm
Terry, here's the rod and its length. One of Ray's links at attached, as you can see. Let me know if you need any other dimensions.
rodlength.jpg and
rod.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: terryp » Fri Jan 27, 2012 4:10 pm
Thanks Greg, at least I know what I am looking for now. I'll give it a few weeks trying to find one and then if I may I'll come back and ask for more dimensions to hopefully fabricate one
Terry
PS Anyone have a spare?
terryp
PostPost by: terryp » Fri Jan 27, 2012 6:11 pm
Oops one thing Greg, Ray's links are very very nice but by the time they get to me with import tax and everything they will be the best part of $130
What do you think of these? ....and can you measure the link so I can check they are OK?
http://www.ebay.co.uk/itm/380056833266? ... 1423.l2649
Terry
terryp
PostPost by: gjz30075 » Fri Jan 27, 2012 6:36 pm
Nice alternative! Ray's link, as currently adjusted to my specs, is 110mm (thereabouts). The stud size going into the headlight pod and rod is 3/16" (6mm?) but the hole in the rod is 1/4", so a bit of leeway there. On the ebay item, looks like you can cut down the turnbuckle if it ends up being too long.
link.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: terryp » Fri Jan 27, 2012 7:17 pm
Thanks Greg,
So 6mm may be a little big (?) and the ends would have to be sorted
So what about these ....
http://www.ebay.co.uk/itm/M5x0-8-RH-LIN ... 20bf0af8c3
http://www.ebay.co.uk/itm/M5-x-200mm-St ... 2316f2bcf3
I think they may be a real alternative?
Terry
terryp
PostPost by: gjz30075 » Fri Jan 27, 2012 8:15 pm
I think I would stick to the entire turnbuckle with joints and come up with a nut and bolt arrangment with spacers to go through the holes in the heim joints. The studs on this one:
look a bit short. One of the ends would have to be spaced out to keep the heim joints from binding.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: terryp » Fri Jan 27, 2012 8:19 pm
Thanks Greg , well that's one part sorted anyway!
Terry
terryp
PostPost by: terryp » Thu Feb 23, 2012 2:48 pm
Armed with a drawing containing Greg's measurements we have just spent 15 minutes with our local artisan ..... and the answer was OUI!
Only problem will be the bar will be 17mm and not 18mm but I think it may have a thicker wall thickness.
So fingers crossed in a couple of weeks ......months....years we may have our part, or something that looks vaguely like it!
Thanks to Greg for the info.
Terry
terryp
