Headlight question.
Mon Dec 19, 2011 11:29 am
by rmd24
Can anyone tell me what limits the travel of the pod in the open position? The RH one comes up a little too far and consequently it illuminates low flying aircraft instead of the road.
Roger
Re: Headlight question.
Mon Dec 19, 2011 11:41 am
by miked
Little screws under the pod with rubber bump stops fitted. One limits up and the other limits down. If you pull the head lamp out you will see them with the pod pushed down a bit through the lamp hole. Also if you look through the air grill with a torch you should see them.
They may be tight. Worth taking pod out and cleaning and lubing the threads. Mike
Mon Dec 19, 2011 11:52 am
by rmd24
Thanks. Having posted the question I went and had another look and I spotted the little bolts but mine don't have rubber bump stops on them, as a result the fibreglass has worn a little and so the problem gradually gets worse.
Next question. The workshop manual shows a clever little tool for removing the headlight rim. I have done this without the use of such a tool but it feels a bit brutal. Any tips for doing this job?
Roger.
Mon Dec 19, 2011 1:51 pm
by miked
Roger, I have seen the tool (like you) in manual but not had one. I tend to have got away with pushing the rim down and flicking the bottom out with a small screwdriver. No doubt you could make little tool out of something.
Mon Dec 19, 2011 2:26 pm
by oldelanman
miked wrote:No doubt you could make little tool out of something.
This one was made from an aluminium shelf bracket........
Mon Dec 19, 2011 4:15 pm
by rmd24
What a splendid piece of kit. I have done the job now but next time I shall endeavour to make something similar.
Roger.
Tue Dec 20, 2011 11:12 am
by Robbie693
I made one out of an old dinning knife!
Robbie
