Rope Seal Alternative?
Posted: Thu Sep 22, 2011 4:53 pm
Hello All:
I've read all the archives I could find regarding proper installation of a rope seal, including this one which was pretty comprehensive:
elan-archive-f16/assembly-rope-seal-engine-t9581.html
Key points being use the graphite type, 1/8" out on each end, don't press too hard on the seal surface.
In my most recent attempt I followed the advice, even made up a jig the same diamater as the crank to push the seal in radially so as to avoid point pressure. The result: fine at idle, but the first time I used the clutch it started leaking again. (end float OK).
I will try again, but before I do, has anyone used a modern rubber seal in this application? Is there one available on a modern engine that is the right size to fit our application?
Darren
Darren
