Indicator Arm
PostPost by: ken ob » Thu Jul 28, 2011 8:33 pm
Hi, it looks like i need a complete new indicator arm for my 65 S2 Elan.
The copper contact parts have worn away. It has Lucas 125 SA and 34828B stamped on it. Is this the same as Triumph Herald or Spitfire? The arm on mine is 6 inches long with a slight curve down then an upward curve.
many thanks, Ken.
Slightly confused by everything since the invention of the wheel.
ken ob
PostPost by: Spyder fan » Fri Jul 29, 2011 11:09 am
Hi Ken,
I'm pretty sure you need the Spitfire item, have a look at Rimmer Brothers http://www.rimmerbros.co.uk/Item--i-GRID005829 this item http://www.rimmerbros.co.uk/Item--i-158966
SJ Sportscars list the indicator switch (with stalk) http://www.sjsportscars.co.uk/index.php?mod=10 there is a photo of the item as well which looks to be the same as the one shown for the spitfire....... I'm sure all the usual suspects will stock this item.
Kindest regards
Alan Thomas
Spyder fan
PostPost by: ken ob » Fri Jul 29, 2011 11:48 am
Thanks Alan. Ken.
ken ob
PostPost by: nebogipfel » Fri Jul 29, 2011 12:18 pm
Spyder fan wrote:Hi Ken,
Yep, all the early Triumphs. Spit, Herald Vitesse etc. Same column, cowls and switch gear except for the mod' on the lighting switch so that it becomes two position :wink:
nebogipfel
PostPost by: paddy » Fri Jul 29, 2011 6:42 pm
There are some reproduction items for sale which are very poor quality. Try to get an original one.
Paddy
1963 Elan S1
paddy
PostPost by: twincamman » Fri Jul 29, 2011 10:18 pm
I use a on center off on switch in the place of the original that way one wont kick the sh22T OUT OF A hundred dollar switch getting in and out of the car --about 4 dollars at any eletrical shop ---ed
twincamman
