Rev Limit?
Posted: Tue May 24, 2011 9:40 am
Hi All
I have decided to invest in an electronic rev limiter for my +2. The question I have is to what rev limit should I set the limiter. The easy answer is of course the 6,500 rpm red line. Is it safe to set it slightly higher? The engine has a standard crank and con rods. The cams have been reground (years ago by vegantune) to a 0.360" lift and the head has been converted (again by vegantune) with big inlet and exhaust valves. The cam fllowers are the lightweight thin pad buckets and the valve springs are standard (as far as I know).
Thanks in advance.
Andy
Thanks in advance.
Andy
