Ballast resistor
PostPost by: Kerryt333 » Tue Apr 26, 2011 5:48 pm
I'm returning my +2 to a ballast resistor coil system& the resistor is the long external ceramic type, whereas the original one was a round disc bolted straight onto the coil.When I bolt the steel mounting bracket for the ballast resistor onto the bodywork do I need to insulate to the fibreglass as the resistor gets pretty hot?
Thanks in advance for any comments
Kerryt333
PostPost by: andyelan » Tue Apr 26, 2011 7:42 pm
Hi There
I wouldn't have thought it necessary provided the resistance wire is clear of the fiberglass. I'll admit I havn't used one myself on the Plus 2 but I have unsed one on a steel bodied car and it's never been hot enough the mark the paintwork in any way. My biggest concern with the later Plus 2 would be mounting it near the coil under the air box. Any fuel dripping on it from the carbs might be more of a problem.
Andy
andyelan
PostPost by: Kerryt333 » Tue Apr 26, 2011 10:19 pm
Hi Andy,
I think I will lengthen the wires to get it away from the carbs.I've found that my +2 starts better with the ballast resistor system.
Thanks for your reply.
Kerryt333
cron
