S1 Battery and Battery Box
Finding a battery that would fit inside the S1 battery box took awhile.
I eventually bought a 049H Varta Blue Dynamic Car Battery 12V 45Ah (Short Code: B24)(Varta DIN: 545 079 030).
It's only45AHr - but as long as the car starts that is less important than the dimensions.
Width and length fit the box - but height was too great - so I decided to build a loft extension.
Didn't need an extension on the positive because that is where my cut-out is fitted - which doesn't fit in the box - and if it did it would defeat the object of the cut-out!
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa - Fourth Gear
Mmmmm!
Might have been less trouble - but I was looking for a battery with (+) at front left and (-) at front right.
That's the configuration I had before - and everything on my car kind of fits that way.
Perhaps next time.
Perhaps next time.
Here's an old photo of my battery box in position behind passenger seat of my RHD.
I use a couple of very long (thin) bolts which are bolted through the two bobbins in the floor where the box is located.
I slide the box over the protruding bolts and then clamp down using large diameter washers and wing nuts.
It's a bit fiddly getting the wing nuts off - but this method works for me.
Lotus14S2 wrote:Does anyone have a photo of the battery cover in place?
There is a picture in this thread elan-f14/interior-batterycover-t17635.html
Thanks for the great photos and information. Although it is not original, I think I'll leave it in the trunk I'm using a plastic boat battery box as used for outboard motors. It was bright red with a white lid; I painted black with plastic paint.
- Lotus14S2
Users browsing this forum: GLB, tonyabacus and 22 guests
