S4 Rear Lamps
I need to replace the rubber seal between the plastic lens & the chromed lamp body. Anyone got a suggestion as to what to use? I don't believe you can buy the original rubber seal.
Keith Marshall
- saildrive2001
Or try this fella
http://cgi.ebay.com.au/LOTUS-ELAN-AND-E ... 48366d0b24
Not quite what you're after but he may be able to track it down. Otherwise I'd be making some up from Clark Rubber or whatever the equivalent is over there.
Robert
Robert
- robertverhey
Replacement gaskets are available; check with Sue Miller.
Greg Tatarian
2 Elans
Greg Tatarian
2 Elans
elangtv2000 - Third Gear
On my Europa TC, same rear light, I used silicone sealer of the kind you can from with a wet finger. Sequuez it in the channel, level if off, and put the lens on when dry. Cheap, easy, and readily replaceable.
RogerFrench - Fourth Gear
If you apply the commercially available liquid anti stick (Wurth for eg) and then gun bead in a good quality clear silicone rubber, when it dries it will lift out leaving you with a nice, durable and better sealing gasket. When the time comes to replace it, Just do the same. Filling the seal channel with silicone works a treat but can be a bugger to remove.
I have some anti stick spray if anyone is wishes to try it.
Great for sealing round the bath too. Gun the silicone, spray the area and use the little tool / scraper to remove the excess.
Std procedure in the glazing industry. Very pro' results with zero skill required... Suits me fine...
I would still try Sue Miller 1st though..
Alex....
Alex....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Already posted, but I too have bought new seals from Sue Miller. Note same light bodies used for Lotus Elan Plus 2s (so could have gone in Things In Common) and also Series II/III Jaguar E-Types. So check out SNG Barratt (page 70 Lamp seating gasket part number BD38161/2)
Gerry
Gerry
- gerrym
I note that (on my screen at least) this thread is followed by some adverts for UK suppliers of sealing materials, with Google being mentioned at the side. I've noticed something similar before. Is Google reading our threads and then coming up with what it thinks are relevant adverts?
PS as soon as I posted this, the adverts disappeared.
Robert
- rcraven
rcraven wrote:I note that (on my screen at least) this thread is followed by some adverts for UK suppliers of sealing materials, with Google being mentioned at the side. I've noticed something similar before. Is Google reading our threads and then coming up with what it thinks are relevant adverts?
Yes, google does that sort of thing.
Unless it can work out if you are the same person (or internet address anyway) that was previously interested in left handed thingummyjigs, in which case it might present YOU with adverts related to those, instead.
One of my rear light seals i noticed filled with water. Upon investigation I note right and left on the seals, differance being a drain slot for any ingress at the bottom. I am to belive that these lights are installed upside down for the elan application so i guess the left installed upside down becomes a right so I ordered a right but got a left. get it.
I cut a slot for drainage, which is about the only useful bit of info here.. and sealed the rest with silicone lubricant , like vasalene.. Perfect.
>.....ELAN 1969 S4 SE COUPE.....<
>...SEE YOU ON THE FLIP SIDE...<
Crusty - Second Gear
There is a source for these in the US. http://www.rdent.com But I'm sure he gets them from the UK. 50M6059/60G
- RKovener
