Wiring Loom
Hi Graham,
The loom passes through the biggest hole just above and to the right (drivers side) of the heater pipes its a wee bit bigger than 3cm, if you need anymore photo's of specific areas just shout.
Innes
Innes
Innes
1965 Elan S2 (26/4681)
1973 Elan+2S 130/5 JPS
innesw - Third Gear
Here's the other photo as you wanted, the ambient temp "sensor" pipe actually exits from the most outboard hole on the drivers side and is routed down round the drivers side of the pedal box, if you understand me.
Rotate the pic 90 degrees counter clockwise as i can't upload it without resizing it again.
Innes
Innes
Innes
innesw - Third Gear
Yes chris that is the wiper motor rack, Graham asked for a picture of the passenger side for the location of the amb temp hole, I might have caused you some confusion as I put up the photo of the passenger side and then explained the hole isn't on that side...
Innes
Innes
Innes
innesw - Third Gear
