Re: Fuses again
Ok - I got the message
Thanks everyone
Robbie
Thanks everyone
Robbie
https://lotuselan.net/forums/
Galwaylotus wrote:Be careful as many meters are limited in the amount of current they can pass. It's often a maximum 10 amps and mine is fused so anything over that means a fuse replacement. Problem is the fuse is an odd-ball sixe and type and not easy to get. For most loads it's ok but if you're trying to measure 17A it might cause problems. Some (expensive) meters can meaure inductive dc current using a clamp on current transducer (CT). A nice toy to have but I've never wanted to spend that much on something I'd only use rarely.
