Water Temp Gauge - Voltage Stabiliser?
PostPost by: oldelanman » Sun Jan 03, 2010 10:47 am
John C wrote...
"I had my capillary type water temp gauge repaired and refurbished recently and it came back with a sticker saying "kettle testing may damage the gauge". Anyone explain why that is ?"
....maybe it doesn't like getting too hot.....100 degrees C is pretty hot..
That's very true John. The gauge scale does go to 110 deg C but maybe that's just so the needle is vertical at normal running temp. Likewise the oil pressure gauge which goes to 60 psi max. If that's true then 30 psi and 85 deg C would be "normal" is that about right? Been a long time since I had my engine running so I can't remember !
S4 DHC
PostPost by: terryp » Sun Jan 03, 2010 11:00 am
Thanks for that John
I'll speak to Susan Miller
Looks like I'll be seeing the correct temperature soon!
Thanks to all
Terry
terryp
PostPost by: alaric » Sun Jan 03, 2010 10:48 pm
Hi all again. On the kettly testing concerns, I tested mine with the sensor suspended dipped into the centre of a saucepan of water that was boiling very gently, so that shouldn't do any harm. At least I really hope not.
All the best.
Sean.
p.s. here's a pic of my temp sensor if it helps.
IMG_3001.JPG and
Temperature sensor Elan +2S 130/5 man. '72
alaric
PostPost by: redskatejbf » Mon Jan 04, 2010 10:08 pm
I do not have a problem at the moment with my 40 year old voltage stabiliser but could someone advise a supplier and a part No. for a Solid State Voltage Stabiliser, I would put it away in my `handy gear` store for possible problems later.
Kind Regards and thanks John.
The lines fall unto me in pleasant places, yea I have a goodly heritage.
redskatejbf
PostPost by: john.p.clegg » Tue Jan 05, 2010 11:07 am
I made up some of these a while ago and should have some left (negative earth only-don't forget to earth the case) if you PM me I'll try and dig them out...
John :wink:
PostPost by: redskatejbf » Tue Jan 05, 2010 9:17 pm
Hi John, Thanks for your kind offer I have sent you a P M, I trust it got through to you as we had a power cut in the process.
Kind Regards John.
redskatejbf
PostPost by: john.p.clegg » Wed Jan 06, 2010 8:37 am
As soon as I've dug myself out of the snow I'll start looking for them....getting to the Post Office is another matter...
John :wink:
PostPost by: bcmc33 » Wed Jan 13, 2010 1:24 pm
john.p.clegg wrote:As soon as I've dug myself out of the snow I'll start looking for them....getting to the Post Office is another matter...
:lol: The snow couldn't have been that deep - mine arrived today. :lol:
Thank's a lot John, my friend.
However, it will be another 6 weeks before the engine goes back in and I will be able to reconnect the battery to see if it works. :roll:
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: john.p.clegg » Wed Jan 13, 2010 3:03 pm
You don't have to wait,just connect a battery to it and meter the output (10v +/- 1%) load or not..
John :wink:
Simon,Leslie...should get yours today,
Stuart,Richard,Paul,John... pending payment
PostPost by: bcmc33 » Wed Jan 13, 2010 3:38 pm
john.p.clegg wrote:Brian
You don't have to wait, just connect a battery to it and meter the output (10v +/- 1%) load or not..
8) Not neccesary - I have every confidence in it (and you). 8)
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: SimonH » Wed Jan 13, 2010 7:47 pm
John,
The stabiliser turned up today, thanks very much.
Simon
SimonH
PostPost by: Shiny_kit » Sun Jan 17, 2010 11:03 pm
My temp sender doesn't look like that - mine has a threaded end, not a spade, with a round crimp on the end of the sender wire which is not a great fit... methinks this may be why my temp is not reading correctly !
Ordered a new one from QED today... will see what difference it makes....
1968 Plus Two
2020 Royal Enfield Continental GT 650
Shiny_kit
PostPost by: Shiny_kit » Sun Jan 24, 2010 6:40 pm
Update - fitted new sender today, temp reading went straight to 110deg, on a practically cold engine ! [I'd only driven it out of the garage]. Took it for a run, temp steady just below red, went up maybe 3mm to bottom of red zone, no further.
So, either the gauge is u.s. or the voltage stabiliser. How easy is it to get to the stabiliser ? Is it a dash out job ?
Was planning on replacing the dash at some point anyway... just not now !
1968 Plus Two
Shiny_kit
PostPost by: alaric » Sun Jan 24, 2010 10:28 pm
Hi. I can't speak from experience as my dash is yet to go in, but the stabiliser is near the edge of the dash as shown in earlier pics in this thread, so it may be poss to reach it by removing the underdash trim. If not then maybe leaning the dash out from the bottom will give you enough clearance, but since this'll involve removing the centre console you're probably not far off being able to pull the whole dash out - wires still attached. I suspect it is indeed a dash out job to replace the standard one. If you can get to the wires, however, it may be poss. to pull them out enough to allow you to fit a solid state reg or a direct replacement one, but not put it back in the original position. Good luck anyway. The dash is the next big job for me. I only managed about an hour on the car over the last week though - family and work keep me busy I'm afraid.
All the best.
Sean.
alaric
PostPost by: Shiny_kit » Sun Jan 24, 2010 11:30 pm
Just tried it again now - on a stone cold engine, turned the key to on and the temp needle goes up to just below the 85 deg marker. Tempted to put the old sender back in now !
1968 Plus Two
Shiny_kit
PreviousNext
Users browsing this forum: lottex and 17 guests
