Adding Lightness
Posted: Sun Oct 11, 2009 7:28 am
Not wishing to go off topic from Gary's Unibrain Still Active post, I wanted to pick up on something he mentioned in a recent post there.
Gary said "After this point in time, the Lotus idea of "moving up market" and the U.S. governments idea of what was "safe" all but ended my idea of what a sports car should feel like to drive. After driving the Monster Miata V8 that my friend recently bought you just can?t hide what the extra weight does to car."
This reminded me of the start of a Jeremy Clarkson review, which he wrote in the Sunday Times on 4 Oct 09. It does, I believe, make a hugely valid point about the increased sized of modern cars and does so more eloquently than I can. Although he used the Lancia Montecarlo as a comparison, he could equally as well have use the Elan. This is what he said:
"About a hundred years ago I used to spend a very great deal of time with my nose pressed against the plate-glass window of an exotic car dealership in Chiswick, wondering if there was anything in life quite so perfect as a Lancia Montecarlo.
So, when I drove one this week, I couldn?t quite believe there was one rather notable feature that I had somehow overlooked. I had spent days taking in every last detail of this twin-cam mid-engined sports car that in effect bridged the gap between the frankly rather weedy Fiat X1/9 and the frankly rather expensive Ferrari 308. You would imagine, then, that I might have noticed it was about as big as my left shoe.
I suspect the reason is simple. Back then, all cars were tiny, even big ones. That?s just how it was. So, the Montecarlo is 5?in shorter than the current Ford Fiesta and narrower too. Technically, that makes it a motorcycle.
There are more examples too. The BMW 1-series is wider and taller than the 3-series you had in the 1980s. And today?s Range Rover is nearly 20in longer than the 1970s original.
All of this raises a question. Why?
If you have been fortunate enough to look around the SS Great Britain, which is now a museum piece in Bristol, you will undoubtedly have been shocked by the size of the beds. They are tiny, more like cots, and there?s a good reason for that. Back in the 19th century, when the ship was built, people were little.
But we have not become that much bigger in the past 20 to 30 years. So why the sudden need for vast cars?
Some would cite safety, suggesting that the crash protection needed to get a car onto the market these days means the car itself must be enormous. But that?s not true. A Renault Twingo is not big and that?s very safe. A Renault Formula One car is unbelievably tiny and that?s safe enough, we?re told, to be rammed, on purpose, into a wall.
I think market researchers are to blame. They go out onto the street with their clipboards and their winning smiles and they say: ?Would you like your next car to be bigger?? And since everyone associates a big car with success and prosperity, everyone says: ?Yes.? The car companies are simply responding to that.
The fact is, though, it?s nonsense, and it?s about time the trend was reversed because I drove that Montecarlo through a Welsh town with a name I can neither remember nor spell and it was a joy. Gaps that would have thwarted even a Mini could be dealt with without a problem. Parking spaces that would have beaten a Citro?n driver were a doddle. And, most important, small cars are not seen as threatening by pedestrians. They smile at you and that makes the world a happier place.
I can think of no reason cars need be any bigger than that little Lancia. There is room inside for two people, an engine, some wheels and, unless you are Nicholas Soames, the weekly shop. Everything else in your car is just wasted air.
It?s much the same story with the little Austin Healey Sprite I drove around Mallorca on Top Gear recently. Among modern sports cars it looks as preposterous as a ballet shoe on a building site. But, actually, it?s the other way around. It?s the modern sports cars that are too big.
And that causes problems because their big, heavy bodies have to be suspended in such a way that they don?t roll and wallow in the corners. That means the suspension has to be firm. So firm that it will break your spine every time you run over a Catseye. They will also break the bank every time you fill up. And your mind when you can?t find a big enough parking space without going to Lincolnshire.
There?s another thing I?ve noticed, too, about cars from not that long ago. The pillars that supported the roof were elegant, spidery little things. This meant there was a bigger glass area, and that made life inside better, especially if you were a tomato. It meant visibility was good too. Inside a Lancia Fulvia or an old BMW CSL, you really could see all four corners of the car from the driver?s seat."
