RVI rev counter bounce
Posted: Wed Jul 27, 2005 6:42 pm
Sorry to drag this up again. My Elan S3 has Lumenition and a Smiths RVI tacho, used to work OK now it bounces over 4000 rpm. I know I could have the tacho internals replaced for a cost but I am intrigued to fix mine, I have experience of electronic design and have a scope and other test gear.
My tacho works fine all the way to 8000 rpm if you remove the optical sensor from the distributor and test trigger the lumenition with a toothed wheel on the end of a small electric motor. I am obviously doing this without running the TC engine. Is this an indication that the problem must be interference from the generator/regulator through the tacho supply line? Seems likely to me. If so it should be easy to fix with a decent earth wire and filtering on the tacho supply line? I would try it right now... but its raining. Any one out there tried this?
