Lotus Elan
Electric washer pump?
PostPost by: patrics » Thu Nov 25, 2010 6:34 pm
Neil,
I might have one - just been to look but couldn't find it will try again over weekend - I need to move some stuff
patrics
PostPost by: smedith » Sat Nov 27, 2010 5:44 pm
Hi All
I would just like to say a thank you to a kind member that sent me a bottle in the post.
Sadly it was a Heller unit not the Tudor unit Im looking for, as seen in the pictures.
If any one has a Tudor unit in any condition, broken or damaged, or can help me find one I would really appreciate it.
Best regards to all
Neil
smedith
New-tral
PostPost by: john.p.clegg » Sat Apr 16, 2011 8:37 am
Yes to all three,especially if it's cold enough where you are to freeze the water (no antifreeze?)...
John :wink:
PostPost by: GrUmPyBoDgEr » Sat Apr 16, 2011 9:41 am
Another possibility is that the switch in the dash has dirty or slightly corroded contacts due to lack of use.
I discovered that fault after fitting a new modern pump which also failed to work.
Actuating the switch a few times brought the required result.
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: RichC » Sat Apr 16, 2011 1:49 pm
when did the electric ones come in?
mines still got the old manual pump one working fine ... certainly fun to use !
RichC
RichC
Previous
Users browsing this forum: rjaxe, rpetersen and 10 guests
