Electrical problem
PostPost by: Phil W » Tue Aug 05, 2008 9:28 am
Some one please help!
I've just replaced the clutch master cylinder seals on m7 '74 2 + S 130/5 and have now got an electrical problem that has me puzzled. The battery will not hold its charge even though its less than a year old - a new alternator was fitted at the same time and the car has done less than 1000 miles since then.
If I charge the battery the car starts first time. The voltmeter shows the battery is on charge and showing 13 volts. When I stop and try to restart the battery is dead.
I've checked the obvious things such as battery terminals, battery negative terminal to earth (in boot - a common problem and I always unbolt this and clean the connection every spring!), alternator connections and starter motor connections but can't seem to cure it.
Anyone got any ideas?
Phil W
PostPost by: garyeanderson » Tue Aug 05, 2008 10:50 am
I would try another known good battery for a start.
Is 13v with the car running? If so sounds a bit low, should be 13.5v to nearly 14v with the engine running.
Gary
garyeanderson
PostPost by: Phil W » Tue Aug 05, 2008 11:04 am
Gary - its probably nearer 13.5 at idle.
I'll swop the battery out at the weekend and give it a try.
Actually thinking about it logically it must be the battery - I disconnect the negative terminal when the car not in use and it still doesn't hold its charge.
Phil W
PostPost by: smokey73 » Tue Aug 05, 2008 1:34 pm
On occasion a battery will develop a "dead cell," (even a brand new battery). When this happens the dead cell becomes an internal load and the other cells aren't happy and try to charge the dead cell, which results in a dead battery over time. Normally when this happens what you will see when you put the battery on a charger is that the charging current will be high and remain high during the charge (not go down like it should)
I have had this on a nearly new battery - the only solution is a new battery. You should be able to take it back to where you got the original battery and get a replacement. (They should be able to test it too and confirm a bad cell)
Hope you get it fixed - not very stylish to be pushing your beautiful Lotus by yourself and jumping in to pop in in gear. Doesn't impress the wife or girlfriend much! Been there - done that - have the tee-shirt!
Dan
smokey73
First Gear
First Gear
PostPost by: RotoFlexible » Tue Aug 05, 2008 2:03 pm
This failure has the same characteristics I experienced when the ground wire for my alternator went bad - except that the battery would not discharge itself when disconnected. If that is really happening, the battery must be bad.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: oldokie » Tue Aug 05, 2008 6:58 pm
It's possible to do a simple 'load test' with a multimeter, read the voltage across the battery, hit the starter and read again. My 'rule of thumb' is more than a 10% drop indicates a battery problem. Hope this helps!
Gene
oldokie
