Voltmeter vs. Ammeter
Please pardon my lack of knowledge, but why is a voltmeter the best instrument for monitoring an alternator while an ammeter is best for a generator?
They both ultimately put out D.C. so I'm missing something!
Stuart - Sydney
1968 +2 50/1035
1968 +2 50/1035
- Stuart+2
You generally use ammeter with dynamo as they are often borderline on output,so you can monitor charge/discharge. alternators normally just work or don't! so voltmeter is adequate.
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
- lotusanglia1965
Alternators can have Faults when the current output is half but the voltage is ok you need a ampmeter to show this.it's the dynamo that tends to work or not . Dynamo are very reliable but only if they are not bodged or the regulators adjusted to the correct settings.
Neil
Neil
- neilsjuke
I always found that the Ameter was a very good indicator for a broken fan belt. It goes into discharge before the temperarure guage goes over the top.
Beware of the Illuminati
I have upgraded my car to an alternator. I wanted to add either an ammeter or a volt meter but couldn't decide. I checked my friend's +2 which came from the factory with an alternator and it had an ammeter. My Europa Special came from the factory with an alternator and it had an ammeter also. So I chose an ammeter because I thought it would be the most "period correct" instrument. Now everyone tells me that in light of the fact that I have an alternator, I should have gone with a volt meter. Oh well...
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
neilsjuke wrote:Alternators can have Faults when the current output is half but the voltage is ok you need a ampmeter to show this.it's the dynamo that tends to work or not . Dynamo are very reliable but only if they are not bodged or the regulators adjusted to the correct settings.
Neil
You went the best way
Neil
- neilsjuke
