So you want to make your headlights Electric Pop Up Eh ?
PostPost by: pmallinson » Tue Apr 29, 2008 12:05 pm
Hi Everyone,, just to prove I have not left and forgotten you all :roll:
Have a look at this place for getting the bits for NOT ONLY your carb connectors, rods and levers but Also adjustable rods that must be perfect for connecting your electric motor(s) for headlamp raising to the cross bar which moved the pods !!
http://www.piercemanifolds.com/linkage.htm
Have fun
75500.jpg and
We are now exclusively handling JPS adjustable rods. These high quality rods feature right and left hand ends for proper center turn adjustment, zinc plating, and 8mm ball pins with safety clips, as used by Volvo, Mercedes Benz, etc. The rods come with am
Peter Mallinson
[email protected]
pmallinson
PostPost by: richboyd » Tue Apr 29, 2008 4:24 pm
Peter,
An excellent resource. Like you, I am fabricating linkage to replace the headlight vacuum pods with electric motors. These bits will speed my fabrication a lot.
Rich Boyd
richboyd
PostPost by: steveww » Tue Apr 29, 2008 5:14 pm
For those of us on the European side of the pond http://www.webcon.co.uk/ have the same items listed 8)
steveww
PostPost by: alaric » Tue Apr 29, 2008 6:11 pm
Hi all. Can this be done with just one motor using the linkage bar that's already in the nose of the car? If that motor failed I guess you'd need to be able to reach in to manually raise the lights.
Sean.
alaric
PostPost by: steveww » Tue Apr 29, 2008 7:14 pm
If you are using the MX5 motors they have a manual override.
steveww
PostPost by: Matt » Wed Apr 30, 2008 12:19 pm
I made my own electric headlamp pod lift motor system a couple of years ago, I used the balance bar and one of the old springs to counter weight it.
It has worked very well, I never had to use the manual override
Matt
IMG_1319.jpg and
1967 Elan S3
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
Matt
PostPost by: alaric » Wed Apr 30, 2008 12:45 pm
Matt, that's brilliant. So using the springs the power requirement on the motor is the inertia of the headlight assemblies while cranking them up or down - as the car goes over bumps. These motors are very highly geared with a worm drive aren't they, so the motor should just pop in where the original vacuum unit was. So comparing the motor force against the vacuum unit should give me a hint on the requirements on the motor.
Which motor did you use?
Thanks.
Sean.
alaric
PostPost by: Matt » Wed Apr 30, 2008 1:49 pm
My motor came from an old toyota supra (?15 form a scrapyard) but it's the same motor as used in the mx5 and even the Lotus excel !
I used the rose joints from the scrap supra and some stainless threaded rod, I made my own control box, I knocked the whole lot up in a morning and haven't touched it since.
If you need help with the control box just let me know
Matt
1967 Elan S3
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
Matt
PostPost by: pmallinson » Thu May 01, 2008 2:53 am
There was another posting on here ages ago on this and a very neat installation which I saved the picture off to use when doing the conversion myself.
But never needed to as the lights and vacuum system worked flawlessly all the time I had it, hence the sale of the pair of motors presently on eBay :
Her is the picture I got from previous forum topic, I can't remember who did this but a VERY neat and professional job
t_rhs_headlamp_motor_and_link_301.jpg and
Picture from previous forum entry
Peter Mallinson
[email protected]
pmallinson
PostPost by: beresneva » Fri Aug 15, 2008 1:40 pm
Matt wrote:I made my own electric headlamp pod lift motor system a couple of years ago, I used the balance bar and one of the old springs to counter weight it.
Matt
Matt, I have a 71 +2130S convertible: very interested tohave more details of your ''one motor'' solution...pictures too...I gues the left hand side of the lotus is freeest for installing the motor right side has the air trunking etc) is this best ? : in which case should I get a LH or RH Mazda motor...? Thanks in anticipation. Tony
beresneva
New-tral
