Page 2 of 2
Re: Auxiliary lamps ( 'S' model )
Tue May 29, 2007 10:39 pm
by chrishewett
My original idea was to have a bit of extra light while driving on deserted roads at night in rural France. Therefore I don't care what the law says on this subject. I have no intention of driving the car in falling snow and I would rather have my toenails pulled out with a pair of pliers than wear a baseball cap, even the right way round.
I wish certain people would just use this forum for an exchange of information instead of trying to gain points.
Chris
Wed May 30, 2007 8:19 am
by sk178ta
Chris, sorry if my cheek full of tongue offended your sensibilities. I was exchanging information regarding legality. A couple of further thoughts: the Elise driving lights only come on with main beam to comply with the law and are aimed much higher than traditional fogs which should spread light low and near. Secondly, technically speaking, 26R light are illegal for road use. The flip up lights on Elans, and others, were to preserve a low frontal area yet lift high enough to comply with the law.
Jim
Wed May 30, 2007 5:17 pm
by chrishewett
No problem Jim. My lights do seem to be the same and driving lights so I am going to have a go at getting them going and see what they are like. The other thought is the proposed "daylight driving light law". If this should actually be introduced (heaven forbid) it may be possible to use the driving lights instead of popped up headlights during the day as they wouldn't cause glare in daylight.
Chris
Sun Feb 16, 2020 9:25 pm
by nickruss
This thread is quite old now, but I wonder if anyone has a part reference or recommended supplier for new fog/driving lights for a 1971 Plus 2s?
Mon Feb 17, 2020 6:04 pm
Lucas Square Eight used on many cars.
Mon Feb 17, 2020 6:15 pm
by draenog
Lucas LR8 = spot light
Lucas FT8 = fog lamp
Tue Feb 18, 2020 6:45 am
They are handy to switch on if your car suddenly suffers from headlamp droop
Tue Feb 18, 2020 6:58 am
by h20hamelan
I have the CLR/SLR700 and 576
Not square lights
Tue Feb 18, 2020 7:09 am
by nickruss
Thanks guys. I’ve got electric pop up motors so no droopy issues.
Just curious (apologies if it’s been covered), to know what the correct lamp setup is? One spot and one fog? Two fogs (my current setup).
Some suppliers of the LR8 refer to the light as a driving light, so this could be a handy thing to be more visible when out and about among the seas of losers SUVs?
Tue Feb 18, 2020 8:34 am
by JonB
It's one fog, one driving lamp.
Most odd.
Tue Feb 18, 2020 9:24 am
h20hamelan wrote:I have the CLR/SLR700 and 576
Not square lights
The Lucas square 8 lamps are not square they are oblong
Some have chrome cases at the back and some are plastic.
Tue Feb 18, 2020 10:02 pm
by h20hamelan
Yes, rectangular arrangement at its finest.
I am changing my oblong rectangular rear to round too.
I dont seem many Élans with Lucas round, thats all
Tue Feb 25, 2020 4:17 pm
by ted
Does anyone have a source to buy the Plus2 flasher/dimmer switch that mounts on the steering column? Maybe a Triumph part? I've looked at the usual suppliers and can't seem to find the appropriate item.
Ted
Tue Feb 25, 2020 4:21 pm
by JonB
The Dip / Main / Flasher switch is available from Canley in the UK
https://www.canleyclassics.com/demoapp/?ptno=147278Little bit expensive at £85 though. It's off a Triumph Spitfire MK3.
Wed Feb 26, 2020 12:56 am
by ted
Thanks, JonB for the info. My car (Elan 66 S2) is LHD with the turn signal switch on the right of the steering column, but Canley also has one for LHD, but is out of stock but available to order. I appreciate that you also gave me the part # as I was also able to find one at Rimmer,, both LHD and RHD so I should be able to find something to work. Thanks again.
Ted
