Page 2 of 2
Re: Rear Lights? shared with.....
Tue Mar 27, 2007 12:09 pm
by pereirac
Of course you can always fit your own rear lights, (I think these are off a Rover)
Carl
Tue Mar 27, 2007 3:08 pm
by Frank Howard
They look like they're off a Turbo Esprit to me, which probably took them off another car.
Tue Mar 27, 2007 3:34 pm
by Jens
Is it posible to prosecute people for doing things like that - or is it seen as a modern version of the late Sir Chapmans use of donor materials?
And by the way, does anyone know if the poor car is still alive?
//J
Tue Mar 27, 2007 3:51 pm
by pereirac
Jens,
It would not be my choice of rear lights but as the owner might read this forum so I won't say what I think. The photo was taken at a club Lotus event in Donnington in April 1990 (I think). I suppose in 'true' Lotus fashion it was a case of using what was available at the time and with a 'rear' like that you would probably be noticed...
Carl
Lenses for S4
Sun Apr 01, 2007 3:27 pm
by Simmo
Many thanks for all the replies, I wasn't expecting that many different answers... I think i will have my original ones refurbished (with me doing most of the work to keep the price down) Anyone tried the product Mazak Mender?
Looks easy enough... I did pick up a scrap lense from the lotus show this year for a couple of quid and will experiment before using it on the originals!!!!!
Sun Apr 08, 2007 3:03 pm
by Leo Leentvaar
I heard somebody say that when you dismantle the rear lenses they come out spic and span out of the dish washer.
Anyone tried that?
Fri Nov 29, 2019 10:08 am
by LaikaTheDog
pereirac wrote:Of course you can always fit your own rear lights, (I think these are off a Rover)
Carl
Jens wrote:does anyone know if the poor car is still alive?
//J
Last taxed 1992... looks like it changed hands in february 1991 and it was green then.. so maybe had some "cosmetic augmentations"..
Fri Nov 29, 2019 2:00 pm
by vxah
S.N.G Barratt are classic Jaguar specialists but they also supply new tail lamps for the S4/+2 Elans.
I guess they twigged the market for re-manufactured E type lamps could be expanded? They are not a perfect replica and a bit of fettling is needed to fit them but finding new/good oe ones is not easy!
Not cheap either at getting on for ?500 a pair a couple of years ago, That said, the oe pair on ebay went for ?815 and I could no see Lucas cast on the body?
Fri Nov 29, 2019 7:36 pm
by pereirac
Try Holdens ?41.07 for lenses and ?198.64 for complete units
https://www.holden.co.uk/p/lucas_l807_type_rear_lamp_lotus
Fri Nov 29, 2019 9:59 pm
by seriouslylotus
That price is plus vat, so nearly ?240 per lamp.....
Fri Nov 29, 2019 11:40 pm
by ericbushby
And, they apparently have not got any. It says ( on order, you can be notified when available)
Eric in Burnley
Fri Dec 06, 2019 9:31 pm
by Matt Elan
The Plus 2 had the Alfa rear lights up to chassis no 50/0177. Then they used the Lucas units as seen on the S4, but they were fitted upside down compared to the Elan. The etype series s2 and v12 used the same base but with different lenses, with no reversing lights.
Those lights on the Elan above are from the rover sd1 and used on the Esprit S2.
The jag Egypt?s
