Installing Alternator
Where are we starting from,dynamo?
convert your tach to neg ground or ad a neg ground one if you are running a pos ground system ---- and fabricate a higher alternator mount to clear the steering column if you have left hand drive ----- and reverse the cables on the battery-to neg ground ----- thats all I did --- ed law
Don't you have to alter the connection on your coil to make the spark jump the right way?
I have some instructions Club Lotus produced in the UK for converting from dynamo to alternator. Email me if you would like a copy.
Carl
Carl
pereirac - Coveted Fifth Gear
When I did mine, I used a combination from the Lotus Manual. Unfortunately, I cannot remember the exact detail. Roy at Paul Matteys was very helpful.
What I do do that was very effective was to use an old control box with the insides removed for my connections. I have no extra wires and the car looks more original when you look under the bonnet.
My car is a 1969 +2S.
Nick. :rolleyes:
Nick. :rolleyes:
- Nick Godfrey
yes :blink: change the polarity on the coil-leads-so neg goes to the points ----ed
