Lotus Elan
jumping out of fourth gear
PostPost by: wolfchen » Sun Nov 26, 2023 9:16 pm
all of a sudden my gearbox likes to jump out of 4th gear, especially when cold, after a long warm up it seems less before I delve into a removal of the component is this likely to be linkage ( which seems a bit less direct than before) or internals ? Not an issue with other gears hot or cold
wolfchen
PostPost by: Fred Talmadge » Sun Nov 26, 2023 11:55 pm
I've had this happen when lifting off the throttle. It was synchros for me, but it could be other things https://mechanicbase.com/transmission/m ... t-of-gear/
Fred Talmadge
PostPost by: StressCraxx » Mon Nov 27, 2023 12:15 am
Worn synchros, worn shift forks, or simply the bolt that holds the shift fork to the shift rod has come loose.
StressCraxx
PostPost by: Elan45 » Mon Nov 27, 2023 5:51 am
Probably 3-4 shift fork is worn. At least today they are available.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
