Lotus Elan
How can i tell what Ration my 2 speed gearbox is?
PostPost by: DreamBuilderiHope » Thu Jul 27, 2023 10:36 am
Hi, HELP!!!!!
Can anyone help me to find out what my 4 speed gearbox ratio is. I do know it came out of a Lotus Elan.
363339489_288165377220373_1492909226433324362_n.jpg and
DreamBuilderiHope
PostPost by: jono » Thu Jul 27, 2023 11:26 am
Mark the input and output shafts and measure the number of turns it takes to make one turn of the output in 1st gear
PostPost by: DreamBuilderiHope » Thu Jul 27, 2023 12:21 pm
Thanks, bur i dont have a gear stick so i cant put it into 1st gear?
Dave.
DreamBuilderiHope
PostPost by: SENC » Thu Jul 27, 2023 12:36 pm
Take the aluminum cover off and count the teeth. I don't have the chart with me, but someone will turn up that does.
Henry
69 Elan S4
65 Seven S2
PostPost by: DreamBuilderiHope » Thu Jul 27, 2023 1:11 pm
Hi Henry,
Have taken off the top but what teeth there are several from lert to right diff thickness?
Dave.
DreamBuilderiHope
PostPost by: SENC » Thu Jul 27, 2023 1:20 pm
The smallest gear (in diameter) is the main/4th gear. I just looked at some notes I had online and it looks like the standard ratio has 17 teeth and the close ratio 19 teeth.
Note - 1st gear and reverse gear have the same number of teeth for the various gearboxes.
Henry
69 Elan S4
65 Seven S2
PostPost by: DreamBuilderiHope » Thu Jul 27, 2023 1:36 pm
Thank you so much Henry!!!!!
Dave.
DreamBuilderiHope
Users browsing this forum: NTG999 and 14 guests
