Clutch not disengaging
Any tell-tale marks on the bellhousing or block where the oil was from?
I'd suggest you run your finger through that oil, rub it between two fingers and have a good sniff. You can then usually identify through both colour and smell whether it's engine or transmission oil.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Alfa Dave,
Further to twin cams observation, my wife always knows when I have drained gear oil, she says it smells like cats wee!
Richard Hawkins
Richard Hawkins
- RichardHawkins
Sense of smell coming back.......yes its gear oil.
Seems the oil is leaking from the front seal and being thrown round the bellhousing.
Front seal carrier came off easily......the oil seal seemed ancient and came out in bits.
SJ give the sizes of the 3 different seals, so I was able to order the correct one, plus a gasket.
And I sealed the lower UK drivers side bolt whilst in there
- alfadave
Looking closely at the input shaft on my 4 speed gearbox....
The shaft tapers up from 22 to 27mm at the point the oil seal sits in the sleeve.
The sleeve suits a seal of 41mm outside diam.
SJ have two items
SJ 026 F0002 41x27x9 mm
SJ 036 F0009 41x22x 8 mm
I think I need the former but not sure.
The old seal was ancient and brittle, and came out in bits. But it seemed like the former.
SJ have two items
- alfadave
Be on the safe side, buy them both...
