Sprint Diff torque rod questions
Posted: Sat Sep 25, 2021 10:31 am
After tracking down some bush locating washers to replace missing ones, some new issues before refitting.
What is the difference between the LH and RH one? Are you able to tell by measurements?
I carefully stored the half moon washers and nuts that are at the chassis end of the rods. So carefully I can't find them! Will a nyloc substitute for the nut and lock nut ?
Are the half moon washers (correct name?) readily available or will I need to get some machined up?
