replacing trans w/o removing engine
I am replacing the clutch in my S3 and am trying to due the job without removing the engine using the info I found here on several post. I got the tranny out and am in the process of putting it back together. The part I haven't figured out is how to put the throwout bearing/arm assembly back in without it falling apart. I tried Mark and he can't remember how he did it since it was 30 years ago.
Just was trying to see if anyone has done this successfully and could give me some guidance.
Rick
Rick
- rcombs
I suppose if you have a lift and a transmission jack it's probably fairly easy. I've always pulled them out together. On the other hand, the shop refurbishing my Elan pulled the engine out by its self. then pulled out the transmission later to replace the clutch and seals.
Fred Talmadge - Fourth Gear
I've never heard of anyone removing transmission without removing the engine, simply because the Gearbox has to come out forwards (because of the central box of the chassis) & the fact that the engine is in the way. Seriously, can it be done?
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Even if you can, I would ask: why? Anytime I feel the need to pull either the engine or gearbox, I remove both (sometimes have even lifted the body!) as there is always something else I find that needs some attention. Having both out, cleaning everything up, sorting the issues and putting it all back together is real work, but then it's good for several years again. I guess I've just learned to take my time and do it once, plus I really don't like doing fiddly frustrating things in tight grubby places anymore....
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
gjz30075 wrote:rcombs wrote: I got the tranny out and....
I don't think I can answer the question but a few of us would like to know more about how you did
this.
I have posted the procedure a few times...... here is one: viewtopic.php?f=37&t=16024
- elancoupe
Sure, you can drop the bellhousing out first then the gearbox, I tried it once, it’s a tight skin your knuckles kind of job, I reckon like bitsobrits says it’s easier to pull the engine out then you’ve got so much more room to play with.
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
I never found doing it this way that difficult, with patience. I have done it twice , without a lift, just me and a floor jack.
For a transmission or clutch issue only I would do it again. No motor lift apparatus, no carb removal, no cooling removal/ refill, no exhaust manifold removal, and so on.
- elancoupe
Thanks for the input everyone.
Yes doing it this way is a pain, but so is pulling an engine. I have been working on this thing for more that 6 years. I was getting ready to pull it out of the garage for the first time only to discover that the clutch wouldn't disengage. I remembered hooking the tranny to the engine under the car, so that is how I started to disassemble it. I ran into trouble, but read posts by Mike and others about doing it without pulling the engine.
The thoughts of having to pull the engine at this point is about more than I can bear. However, I can't figure out how to put that silly throwout bearing assembly into the bellhousing without it falling apart before I can get it on the tranny input shaft.
Unless I get an inspiration, me or someone else is going to be pulling an engine.
Rick
Rick
- rcombs
I jumped at the title even though I knew it wasn't possible. I have felt your frustration, but wnen you get down to it, pulling the engine isn't as bad as thinking about it. And when you do, think about how few get to wrench on an Elan. How's that, better?
- webbslinger
rcombs wrote: I was getting ready to pull it out of the garage for the first time only to discover that the clutch wouldn't disengage.
Are you sure the clutch plate just isn't stuck to the fly wheel?
Very common for them to stick when cars have been sat for a while, mine was when I got it. It's normally possible to free them off with a few heat cycles and few shock loads through the clutch with pedal down.
For mine I had the car fully in the air with warm engine. Started the engine with it in top gear. With clutch down I pressed both the brakes and throttle which broke it loose pretty quickly.
- mbell
mbell,
No, the engine rebuilder supplied a clutch assembly with the engine. I didn't know at the time that it was something special for the hot rodded engine. As it turned out there was about 3/4" of free travel with the standard throw out assembly. I just didn't know at the time to check.
I have installed a new Borg & Beck assembly from Dave Bean on the flywheel. Now it should be a matter of putting the tranny back in. It looks like pulling the engine will be part of that process.
Rick
Rick
- rcombs
