Installing Rotoflex Couplings with Body Off
Sat May 23, 2020 8:06 pm
by Tmac897
I'm finishing up the rebuild of the rear suspension and rear drive train. Everything is renewed and reinstalled but the rotoflex couplings. The body is currently off the chassis, so I don't think I have anywhere near enough weight to depress the rear springs sufficiently by just jacking up the rear hub, to install the couplings. Anybody ever do this successfully?
Re: Installing Rotoflex Couplings with Body Off
Sat May 23, 2020 8:18 pm
by Foxie
Why not load up the chassis with a few concrete blocks to get the drive shafts axes horizontal ?
Sat May 23, 2020 8:27 pm
by StressCraxx
Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
Sat May 23, 2020 8:57 pm
by Tmac897
StressCraxx wrote:Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
Have yo tried this in the past? Concerned that hose clamps might not support that much force.
Sat May 23, 2020 9:07 pm
by vincereynard
Why not simple spring compressors?
Unless you know otherwise I'd have my doubts about
hose clamps. (Plus concrete blocks?)
Good tie down straps would have sufficient strength. Breaking strain well over a ton. I use then to "jack" the drive shaft level to give the best angle of attachment.
Sat May 23, 2020 9:45 pm
by Tmac897
[quote="vincereynard"]Why not simple spring compressors?
/quote]
The “hooks” on the spring compressor I rented from Autozone we’re pretty bulky, and will only fit on about the middle third of the spring. To get the springs and shocks to fit up in the lotocones I had to compress, tie down with zip ties, take the spring compressors off, then fit them on and snip the zip ties. Might be worth a try though.
Sun May 24, 2020 12:37 am
I would not fit the rotoflex couplings until the body if on unless your going to leave the rear suspension compressed. The high couple deflection angle for the time it takes for the rest of the car to be completed risks causing cracking and shortening the rotoflexes life
Sun May 24, 2020 12:50 am
by Tmac897
That makes sense. Guess that’s why there’s not much discussion about it on this board. Thanks for your help.
Sun May 24, 2020 4:35 am
by StressCraxx
Tmac897 wrote:StressCraxx wrote:Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
Yes. I used 4 per spring. Stock springs are only 78#/inch IIRC. I also used them to change dampers with the body on the car.
Sun May 24, 2020 6:53 am
by reb53
rgh0 wrote:I would not fit the rotoflex couplings until the body if on unless your going to leave the rear suspension compressed. The high couple deflection angle for the time it takes for the rest of the car to be completed risks causing cracking and shortening the rotoflexes life
And I suspect it wouldn't do the wheel bearings a lot of good also.
My car was left up on jacks for a few months at a panel beaters whilst I sorted out the insurance/parts after a minor fender bender.
Interestingly, once back on the road, both rear sides had their bearings fail.
Within weeks of each other, and, ( as I keep good records), both well before their time.
Ralph.
Sun May 24, 2020 11:44 am
by JimE
And for the future, to accurately check the condition of the doughnuts the car should be jacked up so that the doughnuts are in the fuly drooped position to reveal any cracks. I checked mine on my +2 and Sprint only yesterday as part of my annual self MoT check. Jim
Sun May 24, 2020 12:14 pm
by vincereynard
reb53 wrote:And I suspect it wouldn't do the wheel bearings a lot of good also.
Ralph.
I think you are probably spot on!
I read "somewhere" that one of the main reasons that Elans have limited rear wheel bearing life is the bearings are subject to a considerable side force created by the DoNuts.
Have you considered installing CV's whilst it is easy?
Sun May 24, 2020 1:36 pm
by Tmac897
vincereynard wrote:Have you considered installing CV's whilst it is easy?
I have considered it, but not in the budget at this time.
Best,
Tony
Sun May 24, 2020 4:03 pm
Hi Tony,
i suggest as Rohan to install Rotoflex/Doughnuts when car is complet.
Sun May 24, 2020 5:37 pm
by Tmac897
alan.barker wrote:Hi Tony,
Yep, that’s the new plan!
Tony
