Odd Noise
Now I knoiw its pretty much impossible to diagnose noises over t'internet but I was wondering if the collective knowledge of the site can offer any suggestions. When I drive the Plus 2 I get a light, relatively high pitched rustling noise from the rear end but only when under power - it disappears on a neutral throttle and the overrun.
It sounds like a stone trapped in a disk dust shield - but there aren't any on the rear. As devotees will know I've had both calipers off to refurb them and the handbrake mechanism, and when turning the hubs didn't here the noise. The drive shafts are Hookes type universal joint type and have been very recently regreased, and I can't see anything wrong. It was there before I set about the calipers and greasing the shafts.
As I said its a very 'light' sound, not a bearing knock or grumble/rumble. Its hard to work out where its coming from but in the RHD car it seems to be from the left (near) side so I guess it could be the diff. Any ideas?
Visit me on matthewvale.com
Matt Elan - Fourth Gear
Pinion bearing dirt shield touching diff nose?
S4 DHC
S4 DHC
- oldelanman
Hi Matt,
Check if your diff is moving around under power due to soggy rubber bushes on the two bottom tie rods, or if the frustacones are going soft.
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Hopefully you will have sorted this by now, but if not——
I am refitting rear bearings in my S4. Simple enough, but problem with dust shields. The shield will be pushed snuggly against the bearing by the circlip.
Problem with this, is that the shield touches both the inner and outer race, therefore surely this will cause the sort of noise you are talking about.?
Have I missed something here, because it seems a very basic problem?
Peter
Peter
- cadwell
