Lotus 5 speed - Gearstick lower ball STL file
Attached is a STL file that shows the approx size/measurement for the plastic ball in the Lotus 5 speed gear stick*. Which is prone to turning into soft cheese like material and needing replacement but can't be bought.
This is based off measurement from a replacement ball Greg (gjz30075) was kind enough to supply me that he no longer needed. Before fitting I took rough measurement and drew it up. It probably not an exact match by likely close enough to work well.
While it should be possible to 3D print I am not sure the finish is suitable for actually use.
* Form Ford Type E box and believe the Type-9 box stick has the same ball.
- mbell
STL file attached to this post...please change the file extension back.
- Attachments
- 5 Speed Gear stick ball (2)_stl_.doc
- Rename from .doc to .stl
- (92.27 KiB) Downloaded 295 times
- mbell
I had one made by a machinist from an existing ball. The attached shows the dimensions.
Either I have it in teh spares box OR JonB has it. It cost a rather frightening £30 as I one off!
- vincereynard
Hello gents and nerds,
A couple of years ago I bought a shifter assembly. at Nec.
I found later out the fork part of it is of a different dimension to the requirements of the lotus -5 box.
However the ball was a perfect replacement and made from iron ( cast or sintered ?)
No more cheese in my box.
Unfortunately the disintegrated cerial did manage to procure a noisy box.
As it is very easy to take the assembly apart and preserve everything for reassembly this could be a cheap way to get a new ball.
C.Garde.
C.Garde.
- c.garde
