Gawd I love this site [gearbox related]
I got the drivetrain reinstalled in my +2 and low and behold, no reverse.
pulled the shifter back out and pushed the reverse arm manually, kinda crunched and now no gears no how.
spent the night growling and pondering how much I could not disassemble and get the tranny cover off, then searched here and found this thread:
viewtopic.php?f=14&t=15211&start=
and realized, I is a boob, and did exactly what he did and while getting the bolts of in situ was not too much fun, it was fine and drove the car around a bit
whew
Thanks boys, i woulda been cryin in my beer
whew
- gus
Sometimes the peg on the bottom of the g ear stick lifts out of the slot in the selector rail and then lets you select more than one gear. The cause is too thicker shim under gear knob.
- alan.barker
In my very first outing with my S2, while shifting into reverse, the gear lever managed to select two gears, catching 2nd gear in the process. As stated, if the shift lever is allowed to be pulled up a little too far, this can happen. I wound up making a small sleeve to fit on the gear lever, just under the sliding washer that interfaces with the lever retaining cup. It took several tries, but if memory serves me, it was about .037". This prevented the gear lever from being pulled up to far, and snagging 2nd gear while selecting reverse. The paper gasket between the retaining cup and the gear box casting was just thick enough to function as a seal to prevent gear oil from leaking.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Users browsing this forum: alan.barker, mbell and 26 guests
