differential oil level
After rebuilding my spare differential, refilling with oil only took only 26 ounces for oil to come out the fill level hole. Lotus states capacity at 2.4 US pints which is approximately 38 1/2 ounces. Any ideas?
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Hi Phil
I had it level on the workbench when filling with oil. Thanks
67 Elan +2
67 Elan +2
- seniorchristo
Craven wrote:Did the same filled on bench, definitely less than stated in workshop manual.
+1
The values in the manual for the diff, gearbox and coolant seem to be mere approximations. In the US I assume a quart for both the gearbox and diff. Then, because they haven't overflowed, I rush out to buy another quart only to discover that a mere splash is enough to fill them.
Fortunately they inevitably leak profusely so you get to use the extra eventually!
Nick
elanner - Fourth Gear
Looks like Lotus may have used the oil capacity of the diff quoted by Ford .. ignoring the fact that the Lotus housing is somewhat smaller than the Ford axle it came from.
S4 DHC
S4 DHC
- oldelanman
Oldelanman
Yes, now it makes sense, thanks
67 Elan +2
67 Elan +2
- seniorchristo
