Knocking noise from gearbox/bellhousing
Ok found the gearbox to be in tip top shape inside - checked crank runout
It is .0160? !
It is .0160? !
- 1963Turnerjohn
End float clearance should be 0.003" to 0.008". Pull off the sump and centre main bearing cap and let us know what you find. Quite possibly a thrust washer has been installed the wrong way around.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2015 Honda City 5spd.
- 2cams70
Did you discover the issue? I'm running into the same problem! Please help
- Harrisbueler1
Hi John
I had a similar sound after fitting a new clutch assembly it was caused by the new clutch taking up the slave cylinder clearance. After adjustment it was ok
I should of mentioned this before you removed the engine but just read your post however you have the crank thrust to sort good luck
+2s130 1971
+2s130 1971
Hawksfield - Third Gear
