bell housing to join Lotus 5 speed box to twin cam
Apologies if this has been posted and answered before, but if it was I'm not getting the search right.
Was the bell housing between the Lotus "Maxi" 5 speed box and the Twin cam, as used in the +2, particular to Lotus? If not, any suggestions as to what vehicle it came off, or alternatives to the alloy Lotus one?
I was thinking of a box off an Eclat or an Elite into a +2.
- ditechspain
Just Lotus ,Elan Plus2 and a few later Elans..
if starting with an elite / eclat box you need to change the bell housing and tail section. Both of these components are rarer than hens teeth and are the valuable part of the Lotus 5 speed. So you may as well find a complete Lotus 5 speed box.
If you cant find a complete Lotus box and want to start with the Elite / Eclat version then its a more challenging journey
The bell housing can be substituted by modifying one of a number of alloys bell housings designed to go between Ford boxes and the Kent block bell housing pattern so they can be bolted to the Lotus centre case. I know of no one doing this on a commercial basis so each one is a one off special.
The tail housing is more problematic and the best alternative appears to be to cut and shut the elite / eclat tail housing to replicate the Plus 2 tail housing and this requires a lot of specialist welding and machining expertise and again is not something that is commercially available and each will be a one off special.
If all that is to much then adapting a 5 speed ford box is somewhat easier even if it does not have the nice "Lotus" cast into the casing top cover
Thanks for that very complete reply.
I managed to pick up a reportedly serviceable Eclat-style box for not much more than people were asking for just the empty casing. It's a spare for an existing working +2 130/5 speed, so if it's this much trouble, the bell housing will come off the existing box if(when??) needed. I just like to have as much as possible already fitted. I knew the back end was special to the Elan.
- ditechspain
