4 speed bellhousing
• Page 4 of 4 • 1, 2, 3, 4
Just to add to the intrigue the Escort RS1600 is listed as P/N 3026E 7505A!
From what I can gather the RS1600 ran a pre-engaged starter with different ring gear which may explain the internal relieving.
Past my bedtime now!
- Attachments
- RS1600 bellhousing.pdf
- (44.74 KiB) Downloaded 98 times
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
2cams70 wrote:Just to add to the intrigue the Escort RS1600 is listed as P/N 3026E 7505A!
Cheers for the part numbers. I too thought the pre-engaged starter might be an issue on these bellhousings but the ring gear appears to be almost identical on size as a inertia ring gear and isn't close enough to foul.
Getting back to a previous post - the 120e bellhousings are ribbed so some sellers try to sell them as fitting Lotus Twincam. As I've shown, they don't!
promotor - Fourth Gear
Do you have a part number for the ring gear fitted to the RS1600? There is another pre-engaged ring gear fitted to later Ford's that is bigger diameter than the one in my photo - that could be responsible for bellhousings needing to be machined.
