Driveline Creek
Hello
Not on my Elan but on my Ginetta G4, it has Pre crossflow 1500cc engine + Elan Gearbox + Live axle (Austin A40)
Basically on inital takeup I get what can only be described as a creeky bed/ floorboard sound for 1 to 2 seconds. No other creeks or vibrations after this?
Initially I thought it could be the gearbox fouling the chassis, so I shimmed this below the mounting and its no better.
It has a late crossflow type clutch with the extender on the release bearing supplied from 105E speed.
Anyone any ideas?
Terry
Anyone any ideas?
Terry
- terryp
Driveline Creek? - that?s in Arizona isn?t it?
I think I?ve experienced a similar sound on another car and it was the brakes binding before letting go. Does it feel as if the car is being held back a little.. if not then forget my suggestion your creak lies elsewhere (maybe Texas).
elanfan1 - Coveted Fifth Gear
What type of springs are you using?
My rear springs used to make a noise when setting off which was the coil over spring rattling against the damper tube. I fitted cable ties at points around the spring to prevent contact.
Ed
Ed
EPA - Second Gear
+1 for the prop shaft u/j?s
- Bigbaldybloke
Change ujs on prop an you can at least tick that off the list. Sometmes you cannot detect any play but when you dismantle you see they a shot
- alan.barker
Are you sure the needle bearings in the ujs were fitted correctly. Sometimes during assembly they move and get damaged. Do you know how they were assembled. If assembled using a drift and Hammer the shock can make them move. It's best to assemble using a clamping action and no shocks
Sorry if i am telling you how to suck eggs
- alan.barker
- alan.barker
Other things that can creek are metallastic bushes especially if they are failing. I remember my uncles TR4 suffered from this especially in dry weather. A quick squirt of WD40 worked wonders
- Bigbaldybloke
