Differential Driveshaft Bearing Removal
Posted: Sun Oct 21, 2018 8:38 pm
I have RD Enterprises CV driveshafts and am currently stripping everything down. My notes indicated putting the integral bearings into the diff case required quite a lot of persuasion, so I was anticipating some effort to remove them. Note that with the RD CV shaft arrangement the driveshaft and bearing are integral with the joint itself , so the Colin Croucher slide hammer approach in not possible without dismantling the CV joint.
I asked RD if they had any advice - got an answer "tap gently until they come out". I didn't like this idea so rummaged through my brain (small) and then toolbox (large) for a better approach.
Eventually found I could reverse my track rod joint splitter and apply outward force quite easily. Means putting on a bit of force then rotating 180deg but non-traumatic and bearing came out nicely. 2 applications 180der appart before a little sound indicating the bearing had stated to move. Picture explains better I think.
