Gearbox check Kingston, Surrey, area
Fri May 18, 2018 4:37 pm
by sepans
My Elan Coupe S3 coupe is undergoing a complete rebuild. I need to get the gearbox checked over in case there are any issues with it, before I refit engine and gearbox any recomendations. Could anyone confirm that 21 teeth on the First Motion Shaft indicates c/r box, and 19 teeth on a semi c/r box. Lastly my centre plate plate measures 8" diameter but my pressure plate 8.6" is this correct?
Thanks sepans
Re: Gearbox check Kingston, Surrey, area
Fri May 18, 2018 4:56 pm
sepans wrote:Could anyone confirm that 21 teeth on the First Motion Shaft indicates c/r box, and 19 teeth on a semi c/r box. Lastly my centre plate plate measures 8" diameter but my pressure plate 8.6" is this correct?
Thanks sepans
Yes all correct although you can fit the 8.5" centre plate if desired.
Fri May 18, 2018 5:04 pm
sepans wrote:I need to get the gearbox checked over in case there are any issues with it, before I refit engine and gearbox any recomendations.Thanks sepans
Speak to "Al .....Promotor" on this site .....he'll sort your g/box out for you.
Sun May 20, 2018 7:14 pm
by daleb
BGH Geartech in Kent are 2000E specialists or Hardy Engineering in Leatherhead, I have used both in the past and did a great job.
