Starter dust cap for alloy bellhousing required
I purchased from Dave Bean an aluminum bell housing and they had no domed starter rear dust cover cap to fit ?
The aluminum bellhousing rear dust cover OD hole measures 2.75? dia.
On my old iron Ford bell housing the rear dust cover hole is smaller OD at 2.5?
Can anyone help with a source for the larger dia domed dust cap/cover?
Thxs
Thxs
- 1963Turnerjohn
I see you are in Michigan somewhere, not sure if near a border area, but Princess auto in Ontario carry a trailer wheel bearing cap (inexpensive) which can be made to fit quite nicely, heavy metal and crowned so fits in chassis (I have used on two trannies) the part itself is stamped in Canada. You could check Harbour Freight ( similar to Princess auto) not sure if they would carry it.
Jack
Jack
- jk952
Hi Jack
Is there a part # for the bearing cap you can provide ? I?ll then try to call them to inquire
Thxs
Thxs
- 1963Turnerjohn
Hi John,
Me again, I was down at the local (30km away store, turns out they do have a larger dia one, measures about 2.730, as what I did on the smaller ones, just made 6 saw cuts in the flange part way to enable bending three tabs 1/4 - 3/8 wide out a part material thickness and snap in nicely, (added some rtv).
Since I was staring at it I bought it so will send if you want it - PM me your address, not expensive, plus a bit of mail cost.
Jack
Jack
- jk952
Don't think my car has ever had one.... Do I need one?
Carl
Carl
pereirac - Coveted Fifth Gear
pereirac wrote:Don't think my car has ever had one.... Do I need one?
Carl
Snap, neither has my Sprint
- alan.barker
There is one on ebay, finishing tomorrow
Search---lotus parts bell housing starter cover---
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Not needed and saves weight
- alan.barker
